Procharger boost 91 octane
They said with my 7.5" crank pulley to run a 5.25" blower pulley.. Puts me at 36,789 rpm impeller speed at 5800 rpm...
Don't think I'll have to worry about belt slip.
I called Procharger to see what they recommended for pulleys to make 10 lbs of boost at 5800 RPM....
Im turning my procharger 8 to 10,000 rpms past its rating because of the hp level im at, really in m4 or m5 territory but never upgraded. With 12 rib i never had belt problems at 48 000 to 50,000 rpms, at 58,000 everything has to be perfect and i had to re-enforce mounting bracket to eliminate flex and was still marginal, fwiw, Smitty
7-lbs of boost and I'd have an efi system that can knock retard.thats why I like the mefi4b,you can watch the knock sensor and spot problems.I use the knock and o2 sensor to dial the tune in.
Great discussion. Is there a preferred system or plug and play setup for knock sensing especially on a low tech carb setup without efi/computers?
I have a pair of 572s with 14-71s on top, intercooled and twin 850 carbs in between 1000-1100hp running 93 and Boostane to get it around 99octane for safety. I really wanna add the O2s (have the FAST kit already), but love the idea of knock sensing, and how to prevent bad things from happening. I am by no means an engine expert, and had them built for me, just curious, might be a nice add-on before I start running the thing hard.
I've heard this argument for years and it just isn't true. Think about it...how much mass is there really in a pair of aluminum rotors? None to speak of...certainly not what we see HP wise in the difference between types of blowers, especially when you start comparing the rpm those other blowers have to turn and the mechanical disadvantage they have. You take away the fact that a roots is technically a compressor...remove that load form the rotors and it doesn't take squat to turn them. You're not measuring parasitic loss due to the mechanics of the blowers, you're measuring parasitic loss in efficiency of how they treat the air. Do the same calculation on a turbo, where there is ZERO mechanical loss and you'll see what I mean.
I thought about the comparison between the 2 drives, hard to compare one drive thats turning suprcharger 10 to 1 at 58,000 rpms vs 1-1 on a roots , I do know the impellor shaft in y M-3 is 20 mm in dia (less than 7/8ths of a inch), I dont think you could spin a old school roots with a shaft that small without shearing it off.
