Rods
Old 12-18-2015 | 11:26 PM
  #211
Originally Posted by ICDEDPPL
I don`t see any Mercury engines with those and they run just fine for hours and hours
Not many mercury engines were making 1.7-2.0 hp per cubic inch, turning 6000rpm or more rpm, with 500lbs of over the nose spring psi. The closest thing to what we run dan, was the 900sc/1000sc. It indeed had stud girdles, with its roller cam, and spun a max of 6000rpm, brodix heads, 10-71 blower, etc.
Most of the others were 5200 max rpm, with fairly light spring pressure, and not making a whole lot of cylinder psi. Opening an exhaust valve against 800lbs of cyl pressure wont be as bad as say 1300psi on a boosted or high power deal.as for the .hp500 500efi, 525, 600sc ,800sc, etc. Those were all mild 5200rpm engines with light springs
The 1075+ up engines use shaft rockers.
MILD THUNDER is offline
Old 12-19-2015 | 12:11 AM
  #212
Originally Posted by buck35
Just what do stud girdles do , is it merely to keep the deflection under control or is there another purpose as well?
if so , why aren't the studs large enough in the first place?
They transfer vibration and harmonics equally to the entire valve train.
ICDEDPPL is offline
Old 12-19-2015 | 01:31 AM
  #213
The 850sci also uses the same shaft rocker set up
Bawana is offline
Old 12-19-2015 | 02:03 AM
  #214
Originally Posted by 33outlawsst
Me ether
What vale covers are you using with those??
Bawana is offline
Old 12-19-2015 | 01:36 PM
  #215
Originally Posted by mike tkach
not sure what you mean by outboard end,the way i see it they are all tied togeather.
With the girdle installed they're all tied together but otherwise the outboard end, where the polylock goes, is free to deflect as it sees fit.
Cole2534 is offline
Old 12-19-2015 | 01:45 PM
  #216
F-2 Speedy's Avatar
There are a cast aluminum, very nice for the price, I got them off ebay.
these are them but they machined breather in them, notice no lettering. I paid about 160 bucks a pair for mine
http://www.ebay.com/itm/NEW-TEAGUE-C...pWazkw&vxp=mtr
F-2 Speedy is offline
Old 12-19-2015 | 02:00 PM
  #217
I'm not sure if it's me or the beer, but that pic is fuzzy!
Check your PM's!
Cole2534 is offline
Old 12-19-2015 | 02:09 PM
  #218
F-2 Speedy's Avatar
its fuzzy, I got ur pm............why u drinkin so early
Old 12-19-2015 | 02:15 PM
  #219
Just a good day to drink and make chili!
Cole2534 is offline
Old 12-19-2015 | 02:17 PM
  #220
i think you mean the top of the stud.the flexing will actualy happen from the bottom of the poly lock to just above the mounting hex.the higher the lift&spring pressure the more stud deflection.
mike tkach is offline
