Rods
Old 12-19-2015 | 05:51 PM
  #221
Has anyone put stud girdles under these style valve covers? I am going to add valve spring oilers which will raise the valve covers about .625. Just wondering about clearance issues.[ATTACH=CONFIG]549055[/ATTACH]
Bawana is offline
Old 12-19-2015 | 06:02 PM
  #222
Originally Posted by mike tkach
i think you mean the top of the stud.the flexing will actualy happen from the bottom of the poly lock to just above the mounting hex.the higher the lift&spring pressure the more stud deflection.
Yes.
Cole2534 is offline
Old 12-19-2015 | 06:21 PM
  #223
I cant answer that . But! I have had some valve covers that had clearance issues, and used a .312 thick gasket from felpro , with good results.
MILD THUNDER is offline
Old 12-19-2015 | 06:30 PM
  #224
What style did you have the issues with? I plan on using the same oilers that Dan used, so I think it will work. I don't want to change covers, cause I welded fittings on these for AN fittings to run to my barf tanks and have a ton of hours into these three sets.
Bawana is offline
Old 12-19-2015 | 06:37 PM
  #225
They were some low profile units, lower than those finned ones you have. It was that the poly locks were touching . Non girdle setup.
I can get some measurements for you from those tall valve covers tomorrow, like posted here. And on dans oilers .
Old 12-19-2015 | 06:43 PM
  #226
14 apache's Avatar
I don't think a girdle will clear those covers even if you raise them .625 probably need 1" to clear them.
14 apache is offline
Old 12-19-2015 | 07:00 PM
  #227
Thanks Joe I would really appreciate that.
Bawana is offline
Old 12-20-2015 | 03:58 PM
  #228
Willie,
So the tall angle covers i have and 33outlaw has, measure 3.5" inside . Spring oilers .430 thick.
Old 12-20-2015 | 04:29 PM
  #229
BTW my springs 2 years later tested psi same as brand new. Spring oilers helped possibly...
ICDEDPPL is online now
Old 12-20-2015 | 05:24 PM
  #230
Willie,
Thanks again Joe
Bawana is offline
