Piston pic.
Old 12-04-2015 | 09:59 PM
seems most of them look like this (black)
.. the rings are all there...
ICDEDPPL is offline
Old 12-04-2015 | 10:38 PM
Looks like a childs and Albert zero gap second ring
MILD THUNDER is offline
Old 12-04-2015 | 10:58 PM
yes,the company is now childs&ackerly i believe
mike tkach is offline
Old 12-05-2015 | 12:17 AM
Yes they are couldn't see the step in the ring in previous pic.. also has the support rail for the oil ring too...
I use the stainless total seal gapless upper rings in mine but those are also great rings...
adk61 is offline
Old 12-05-2015 | 06:43 AM
SB
I totally understand gapless top ring - but since their conception (seemingly a few eons ago) I've never been able to wrap my little pea brain around any benefit (just negatives) to a gapless second ring. What am I missing for benefits or possible benefits of gapless second ?
SB is offline
Old 12-05-2015 | 08:32 AM
Gapless second rings came from when the gapless tops started getting thinner, but they didn't have the material technology to stand up to the heat and abuse. They then started moving the gapless ring to #2 but since then, ring technology has come a long way the the gapless 2nd is a thing of the past. With a gapless 2nd, all the top ring does is protect the 2nd...it can't do much for compression.
horsepower1 is offline
Old 12-05-2015 | 08:34 AM
Originally Posted by ICDEDPPL
Since my last thread went so smoothly Figured I`d ask another dumb question since I`m always trying to learn, (don`t know much about bottom end stuff)
Just wondering if this is normal for the piston to be so nasty near the exhaust valve but looking good everywhere else. ??
Same piston.
Very typical to see that on the ex side of the piston. That's where all the heat is and where all the gasses concentrate on the ex stroke. Any un-burnt fuel and oil will accumulate there and get baked on the piston. Engine was sealed up nicely.
Old 12-05-2015 | 09:13 AM
^^^^ that answers my question, thanx.
You can see there`s a bit of scuffing on the skirt, that is also on most pistons even on the "good" motor. Thoughts on that?
ICDEDPPL is offline
Old 12-05-2015 | 09:26 AM
if you can,t feel the scuffing with your finger nail it is nothing to worry about.
Old 12-05-2015 | 10:14 AM
Is that from piston slap?
frickstyle is offline
