Piston pic.
Old 12-07-2015 | 10:55 PM
  #41
i get a pretty good deal on j&e shelf pistons.
mike tkach is offline
Old 12-08-2015 | 04:39 AM
  #42
SB
Originally Posted by MILD THUNDER
Dan, if you were to use the piston rings JE suggests with those inverted dome 4.500 bore pistons, these would be them.
http://www.summitracing.com/parts/jep-j100f84500-5
http://www.jepistons.com/Products/257942.aspx
Summit Price $214.23
Amazon has 8 sets in stock. $167.31
http://amzn.com/B002VI2IYA
SB is offline
Old 12-08-2015 | 05:34 AM
  #43
those we won't work,,you need custom,,custom everything or the engine won't run right.
sutphen 30 is offline
Old 12-08-2015 | 08:51 AM
  #44
Very good..........that's actually pretty funny.
benjen is offline
Old 12-08-2015 | 09:54 AM
  #45
Originally Posted by ICDEDPPL
Mike @ high Flow likes Flat top pistons .. his explanation was something to the effect of
I can`t swing new pistons so I`ll stick with what I have as along as they are still ok.
Dan I would use the pistons you have. What I do with my stuff & others ,is coat them. I have a blast cabinet that is only used for pistons. I ceramic coat the tops & teflon the skirts. The light scuffing on the skirt is gone after blasting and coating. I use a specific blast media per cal-coat, and then bake the pistons.
Bawana is offline
Old 12-08-2015 | 10:14 AM
  #46
[ATTACH=CONFIG]548531[/ATTACH] Here are some that I did that were slightly scuffed.
Bawana is offline
Old 12-08-2015 | 10:27 AM
  #47
Wow, nice work! Can I send you my pistons ??
I`ll wait to see what needs to be done to the bores then decide coat pistons or 548ci. Might be nice to start with a fresh bores.
ICDEDPPL is offline
Old 12-08-2015 | 10:28 AM
  #48
2010 Ford Supercharged 5.4L
Plasma Moly Carbon Steel Top ring
Mahle part 42112CP
http://catalog.mahle-aftermarket.com...rId=784222&d=t
6.0 LS GM Engine
Plasma Moly Carbon Steel top ring
Mahle #41858CP
http://catalog.mahle-aftermarket.com...rId=615547&d=t
6.4L SRT Hemi engine
Mahle #42156CP
Plasma moly Carbon Steel top ring
http://catalog.mahle-aftermarket.com...Id=1206357&d=t
Isnt "MOLY" a coating on the face of the ring, and "plasma" the process used to apply the coating? I've always assumed a top ring is either Steel, or iron, with a "MOLY" coating applied to the face. Pretty sure OEM's have been using moly faced steel top rings for some time now.
While what the car makers use is informative, one factor has to be considered - they absolutely do not use the same costing criteria we do. Another $20 (or even $200) for rings for us isn't an issue. Another $20 per engine for them better show another 20+ hp OR a reduction in warranty that more than offsets the cost.
Otherwise, the engineers are stuck using the cheapest ring that will get the job done.
apollard is offline
  #49
I don't put together a blower motor without coating the pistons. That stuff is Da bomb . I rebuilt a motor that a spring broke, piston hit the valve, put a big smiley in the piston. I thought oh ****, have to get new pistons, but after blasting the ceramic off, the smiley was only in the coating and slight mark on the piston. After recoating, it looked brand new. I have also noticed that the bottom of the pistons don't show any signs of burnt oil. I also used coated bearings on everything, The bearings are just a insurance thing, but I really think coating pistons helps a lot.
Bawana is offline
Old 12-08-2015 | 10:34 AM
  #50
articfriends's Avatar
I do same thing, swain tech gold coat top and std skirt coating, i used diamonds in house coating, was weak and wore off fwiw
articfriends is offline
