500efi power steering >
Old 12-06-2015 | 06:53 PM
Default 500efi power steering
Does anyone know a part number for a pully set up that replaces the power steering pump? My boat only calls for one steering pump and my 500efi both have pumps on them so I'm looking to delete one pump. I need the pulley set up in this pic on the right side motor
[ATTACH=CONFIG]548421[/ATTACH]
twin69 is offline
Old 12-06-2015 | 07:21 PM
F-2 Speedy's Avatar
Just return the fluid to the pump and call it good
F-2 Speedy is offline
Old 12-06-2015 | 08:30 PM
Ya. Then tuck a hose into your parts kit that is long enough to reach from the unused pump to the main pump, boom redundant pumps.
Symmetry is sexy anyway.
Cole2534 is offline
Old 12-07-2015 | 03:57 PM
Anyone actually know where I can just replace it with an idler pulley in the pic? Thanks
twin69 is offline
Old 12-07-2015 | 04:12 PM
F-2 Speedy's Avatar
there all over ebay, its smaller than the ps pulley so you need a different length belt, the bracket will be harder to find than the pulley unless you go to Mercury and pay out the yang for it
Old 12-07-2015 | 07:07 PM
Let me clarify... Does anyone know the part number for the bracket and pulley set up the replaces the power steering pump?? Just like the pic shows above on the port side motor
twin69 is offline
Old 12-10-2015 | 06:39 AM
mo3d's Avatar
I'd be interested buying the pump you remove
mo3d is offline
Old 12-10-2015 | 03:39 PM
I have that PS eliminator set up on one engine, but I don't believe there is a part number on it. I'll double check later.
Try sending a PM to Mbam. He can most likely find it for you also.
Griff is offline
Old 12-10-2015 | 09:57 PM
Thank you!
twin69 is offline
Old 12-30-2015 | 12:29 AM
I checked and there is no part number on the eliminator bracket that I can see. The bracket has some spacers to get it in alignment with the other pulleys
On mine, the standard adjustable idler pulley is replaced with 4.5" idler pulley and a second 4.5" idler pulley attaches to eliminator bracket.
They are both just composite Dayco idler pulleys.
Griff is offline
