-   -   hylift johnson lifters. (https://www.offshoreonly.com/forums/general-q/333082-hylift-johnson-lifters.html)
mike tkach 12-13-2015 09:50 PM
i am pretty sure they are 2 different company,s.
hylift johnson is a lot less money than johnson.one usually get,s what he pays for,or less.
Full Force 12-13-2015 09:52 PM
From someone I know at Johnson Lifter
"Completely different. We used to own Hy-Lift and that building. Back when we focused purely on OEM work and basic aftermarket stuff. Comerica pulled the credit lines for the OEM, that's when Federal Mogul tanked along with a few others. We moved to Taylor, MI and started the aftermarket manufacturing. We also trademarked the Johnson Lifters name. Fast forward a few years and the offshore company, Topline, bought Hy-Lift and our old building."
MILD THUNDER 12-13-2015 09:58 PM
Originally Posted by mike tkach (Post 4384910)
i am pretty sure they are 2 different company,s.jo
Were you able to compare Johnsons side by side? To see if there were any visual differences?
mike tkach 12-13-2015 10:01 PM
no,i just did not have the time but that will change for 2016 pri.i will have all the time i need.
mike tkach 12-13-2015 10:04 PM
i had heard the same thing.i really thought the hylift johnson ones looked chinsey,but looks can be decieving.
Full Force 12-14-2015 05:13 AM
I sent Randy a message to see since I was not 100% sure, but thought he told me in the past they were separate.
HyFive578 12-14-2015 06:32 AM
Hylift Johnson and Johnson are definitely different companies. The latter are better lifters. Had I known at the time, I would have gone with Johnson.
ICDEDPPL 11-22-2018 11:16 AM
Is there anymore info on this since 2015?
Someone I trust who has never steered me wrong says the guys from Johnstone USA use to work for HYlift ... stole a bunch of plans and equipment and started Johnson USA . One of the owners is apparently still in Jail?
HYlift Johnson is still making lifters, the have extremely tight tolerences and machines worth millions to make sure the lifters are top notch.
Some of the practises of Johnson USA uses to build lifters seems to be questionable (according to my source)
I`ve run Morels for 5 years without a hiccup but now they`re quality seems to be in the toilet so I need a replacement. Teague , Eddie , Isky, they all use Johnson USA so I`m confused...
Edit:
https://www.mlive.com/business/west-..._muskegon.html
Maybe thats what he was talking about
And company officials blame the decline on Hicks, for stealing and selling more than $1 million of the company’s parts and equipment in 2006 and 2007 to benefit a competing company Hicks and others were setting up.(JOHNSON USA????)
ICDEDPPL 11-22-2018 11:48 AM
Spoke with Joe Lewis, Product Manager at Johnson Lifters in Taylor, Mi. He was very eager to answer any of my questions. Wish I had some better tech questions but basically I told him of the problems so many were having with "other, offshore" lifters bleeding down and being noisy after they sit idle as so many classic cars do. He explained why their product solves this problem but I can't really explain here as it was a bit over my head. icon_smile_wink
I mentioned the confusion with the Topline Hylift Johnson lifters and this is what I was told.
When the original Johnson went bankrupt back in 2003 or 2004 they (Parent company Specialty Engine Components LLC) bought the rights to the Johnson lifter. Many of the employees came to work for them and the original plant on the west side of Michigan (Zeeland I believe) sat idle for a couple of years. He said nothing negative about the other company. If I remember right from the article about the other company's problems they were bought by Topline, the plant was moved to Muskegon and they resumed production. The only thing I can figure out is there must be enough of a difference in the name (Johnson lifters vs. Topline Hylift Johnson Lifters) to pass muster.
hmmm
the deep 11-22-2018 11:52 AM
WHY JOHNSON HYDRAULIC ROLLER LIFTERS BELONG IN YOUR ENGINE
https://johnsonlifters.com/portals/0...-11-175119-913 https://johnsonlifters.com/portals/0...-11-175119-973
Johnson Lifters wants to be your valve lifter source. A primary supplier with top tier manufacturing capabilities, the 90 year old company functions seamlessly within the high stress, low tolerance OEM environment where quality control inspections are mandatory and frequent. An essential part of Johnson Lifter's quality control program is identifying and solving common lifter issues. In particular, hydraulic valve lifters have long suffered the notion that they are no good for performance use, but that is far from accurate.
