Which carb adapter plate? Merc 454 >
Old 01-04-2016 | 10:15 AM
evaluex's Avatar
Default Which carb adapter plate? Merc 454
My mercruiser 454 (GEN V) has an aluminium intake manifold # 6269318.
(“rectangular port aluminium” is all info I can find on the internet.)
= “quadrajet” spread bore
I bought a (as good as new) EDELBROCK 4BBL carb # 1407 2199
= square bore / 4 same sizes plates
Which adapter plate do I need? Any part numbers?
evaluex is offline
Old 01-04-2016 | 10:17 AM
The edelbrock carb should have both bolt patterns, so an adapter is not needed.
Mr Maine is offline
Old 01-04-2016 | 10:26 AM
evaluex's Avatar
Carb is too low to manifold, so spacer plate is needed ...
evaluex is offline
Old 01-04-2016 | 10:28 AM
As long as the throttle plates on the carb will fully open when installed on manifold.
GLENAMY 242SS is offline
Old 01-04-2016 | 10:32 AM
Gotcha, Edelbrock 2696 is the part you need then.
Mr Maine is offline
Old 01-04-2016 | 11:06 AM
evaluex's Avatar
Perfect, thank you fast replys
regards peter
evaluex is offline
