Marine Lubrication Update Thread
3pointstar
Mobil 1 info:
Driven Its a 15w -50 and if you want just call Lake Speed Jr of Driven to get a very good education about oils and not pushed on Driven only. I have talked to him many times and they have tested everything on the market
Ask him about bike oil so he can tell you why not to use it for marine / race car apps. Go to a source that has real testing results and works with the oil additive companies year in and year out.
Also oil is all about balance, too much of one or more additives will over power other additives and stop them from doing their job as well. One oil might work well in one app but not in another.
Too much zinc and phos is not good either.
^^^^^ If you need phone contact info I have it. The guy really knows his stuff and trained very well, plus he will not push you on their products.
I experimented with case hardening, dlc coating and cryo iso rem of Mercruiser outdrive gears behind 1000+ hp in my Baja, I found that cryo isorem doubled the life of the gears (from piiting/galling, wearing, not teeth snapping), I did extensive testing again, and again. I had a large supply of Royal purple gear oil at time (55 gallon drum) so I used it thru out my testing as a constant. When I ran out I switched to amsoil sever gear, my gear life doubled AGAIN. IN MY OPINION royal purple is garbage, I would buy dino oil before I ever bought that again for anything, fwiw, Smitty
also curious about Brad Penn 20w-50? Ran BP this past season and will be going in for oil change when i do cam change in my SBC 434 in a few weeks when i can catch a few warm days here in SC. Any thoughts on a filter-mag as well?
I'm also curious about the Brad Penn 20/50. My motor came with BP 10/40 and was going to move to 20/50 but found this little gem of a review on a car forum:
The problem was after the car sat for a month the oil turned to jelly.
The Brad Penn PG 1 20W-50 was formulated on the API SJ platform…although it is not a licensed SJ due to the enhanced AW package.
Modern oils meeting API SM or SN are designed to be run in conjunction with E85 fuel. However, 20W-50 is not a recognized ILSAC category oil (GF-4, GF-5). If it is your intention to run a 20W-50 viscosity, I would utilize a product such as Mobil 1 full synthetic meeting SJ and the desired viscosity.
Hope this helps,
Ken Tyger
Technical Services
American Refining Group, inc.
Hope this helps,
Ken Tyger
Technical Services
