460 Commanders to a Bravo drive? >
Old 01-14-2016 | 06:03 PM
Originally Posted by BUP
Just adding info on top of - OMC cobra transom assembly will not cross over / install conversion over to a Mercruiser Bravo transom assembly. The cutout is different
john,are you sure.i was thinking the king cobra was like a bravo.
mike tkach is offline
Old 01-14-2016 | 07:57 PM
Like was said before, unless you are a glutton for punishment, run away fast and don't look back. If you could get them for free, turn them around to a car guy that likes BBF's. There are a lot of jet boat guys that run the 460's. Just a thought.
gofastboater is offline
Old 01-14-2016 | 09:07 PM
If they are later flat top forged piston 460s , they have some value. 8to1 base motors ,not sure i would take them for free. Even if i had the room . And the base 460s wont have the nads on the top end a base 454 will have .
Even if you get it in there i want to see you obtain 2 raw pump assemblies that you can live with.
airjunky is offline
Old 01-14-2016 | 09:13 PM
I say go for it! I'm building 2 small block Mopars myself, dare to be different. As for raw water pumps. I made adapters to use crank mounted pumps. It just takes a little ingenuity.
murfman is offline
Old 01-14-2016 | 09:23 PM
Actually TCI makes a BBF to Chevy trans adapter that should work
http://news.compperformance.com/Instructions/529700.pdf
murfman is offline
Old 01-14-2016 | 10:08 PM
Dont know diddly about the commanders, but have been through 460's
the forged piaton 460s with a real carb are suprising.and can be had cheaper than a 454 mag.
The diahed piston 460 is going to deliver about the same top speed as a decent vortec 5.7. And those are really cheap. And bolt right up to a bravo.
airjunky is offline
Old 01-14-2016 | 10:13 PM
The old elusive volvo penta high compression 460s with pcm style risers and the holley 750 vac secondary carb were actually quite impressive . But im just flat out not big on the ford thing
airjunky is offline
Old 01-14-2016 | 11:10 PM
BUP
Mike I do know 4 sure about the Cobra but not sure about the King Cobra crossing over to a Bravo. I will have to look that one up. I hate to be stumped but will find out 100 %.
BUP is offline
Old 01-15-2016 | 12:05 AM
Originally Posted by phragle
BBF and SBF the same bellhousing?? The merc188 was popular centuries ago, its a 302 ford
Nope totally different bolt patterns.
jekyl is offline
Old 01-16-2016 | 03:41 PM
they are cheaper for a reason...
ezstriper is offline
