Head Gaskets >
Head Gaskets
Head Gaskets
Old 01-24-2016 | 02:47 PM
X2 on the Copper Coat with MLS gaskets, especially if you're not quite sure on the deck surfaces.
Having said that, sometimes we can "out-tech" ourselves and create problems that don't exist. There's no reason you can't use a conventional gasket on your build with 100% success. No need for MLS gaskets.
horsepower1 is offline
Old 01-24-2016 | 03:44 PM
eightsecmopar's Avatar
Thanks guys I appreciate the help. I think I'm really leaning toward the conventional FelPro head gaskets.
I agree 100% about creating problems with new technology sometimes.
eightsecmopar is offline
Old 01-24-2016 | 04:23 PM
vintage chromoly's Avatar
We just used fel pro MLS gaskets on my stuff. We sprayed both sides with copperccoat.
vintage chromoly is offline
Old 01-24-2016 | 05:42 PM
i know a guy who races a small block ford and sprays a ton of nos,he uses mls gaskets and reuses them whenever he needs to remove a head.he uses a spray sealer[cant remember what brand]and it works so i guess if one feels the need to use a sealer it won,t hurt.me,i follow the directions the manufacturer includes with the gaskets.i have an engine that uses copper gaskets along with a wire&reciever groove.i used hylomar as a sealant but now i just use a smear cote of the right stuff around the water ports with no problems.
mike tkach is offline
Old 01-24-2016 | 06:24 PM
Originally Posted by MILD THUNDER
Fwiw
Mopar vehicles use MLS gaskets. When R&R ing a cylinder head, their bulletin specifies using a mopar spray adhesive on the new gaskets.
I had one engine with cometic mls that i copper coated gaskets, the other with uncoated fel pro mls, no leaks on either after 4 seasons
I was just going to mention this. GM also stated to use a specific spray sealant when using MLS gaskets on certain engines. I will not use a MLS without it. Still have several cans from my dealer days!
Jason3603 is offline
Old 01-24-2016 | 07:29 PM
all mls gaskets are not all created the same,fel pro&cometic incorperate a sealing agent on most of their mls gaskets.most others making mls gaskets do not apply a sealing agent.also,mls gaskets have been around for a long time but today,s are better than ever.back in the old days we used to spray silver paint on mls gaskets as a sealer.
