modified 502mpi intake on 502 dyno session at my shop >
Old 02-19-2016 | 11:03 PM
  #141
articfriends's Avatar
Originally Posted by Trash
I think I know the answer to this but have you done any testing on the Merc small blocks with the equivalent intake and throttle body from the same year?
No I havent, havent seen a mefi3 small block in person , sorta strange that some got TBI, some got mpi and some got Carbs even in the 90's.
articfriends is offline
Old 02-19-2016 | 11:16 PM
  #142
Originally Posted by SB
Smitty, what I have found around here, is no one uses 89 octane in their vehicles. When it is boat season (June thru August) more 89 does get pumped.
On top of that, Premium only gets pumped more when it's Harley season and Snowmobile season. Bikes and Sleds don't take a lot of fuel....so I know the Prmium takes a while to get to a level where he station re-fills it. Add a winter like this, no sledding, no Premium being pumped.
If you watch the pumps with cars, you'll see everyone goes for the 87. This trend started when 87 octane gas went over $4.00 a gallon. I would see people with cars that required 91+ and the owner of the vehicle reached right for the 87.
We had a winter where lots of sleds burnt down using the Premium, and I traced it to two gas station, with a high percentage from 1 station. This was during the $4.00 + gallon years. I think Premium was like $4.60 or something like that.
So, maybe your 89 is old ? And/or maybe the 'winter blend' is adding issues ?
Just throwing stuff out there.
I have burnt sleds down from stale premium that had water in it or station owner lied about octane in remote towns in Upper Peninsula of Mi.
Around here most gas stations have a "premium" tank and a base gas 87 octane tank, the 89 is mixed at the pump as it dispenses. I bought 20 gallons of 89 at the same shell when I first started tuning this then 15 gallons more and at 36 total timing would only get fractional KR (less than 1 dgree) IF I loaded brake too long/made really slow pull where motor was maxed out and not barely climbing. All of a sudden this week its got 3-4 dgrees KR on latest batch of 89 from same station with same tune, same afr, same timing, distributer not touched etc and we know its NOT mechanical since it goes away with 93.
The tach drive adapter on the dyno going to the depac was acting up last week, took it apart, shimmed spur gear in it, seemed ok for a day then at end of this latest test it started faltering again so no more dynoing till new one comes from Depac and Depac box is re-programmed to recognize it as it turns crankshaft speed and old one was geared down 2-1.
Old 02-19-2016 | 11:29 PM
  #143
Originally Posted by Panther
I detonated a brand new engine back in 2010... Upon tear-down there was absolutely NOTHING wrong with the engine... Put it back together and ran it from 2010 to 2014 without any issue. I blamed it on getting bad fuel.
Efi or carb? I had a 2 stroke snowmobile that was a octane monster and everytime I got crap premium it blew up, It took me a while to realize it wasnt from a lean condition but a lack of octane. When it would blow up from being lean it burnt center of piston away then did a 4 corner seize/scuff from the heat expanding the piston. When it would pre-ignite detonate it burnt side of piston facing exhaust port and crown into the rings on exhaust side. So thats why I ask if efi or carb, did you end up giving it a little more fuel to be "safe" when you re-assembled it or it was definately octane? did it scuff the pistons, break rings or tulip valves?
Old 02-19-2016 | 11:34 PM
  #144
I wonder what it would have done with the 525EFI cam?
Not sure, big blocks love duration and lift if heads and compression support it BUT keep in mind that these intake restricted motors as you add more duration and lift to move hp peak up at a certain point it will give up more tq than the hp it gains since the intake runner length will keep it at 5600 or 5700 modified and even lower in stock form although a 525 efi cam COMES from a restricted intake engine! Would be interesting!
Old 02-19-2016 | 11:36 PM
  #145
You sure you didnt have a porous case that leaked when hot?
phragle is offline
Old 02-20-2016 | 12:32 AM
  #146
The 95 350 Mag EFI/MP had the same throttle body as the big blocks when they were MEFI 1. Thanks though.
Trash is offline
Old 02-20-2016 | 04:58 PM
  #147
Panther's Avatar
Frank's Marine Service
It took out the side of the piston near the intake valve. I didn't add any more fuel as I added 2 jets in the secondaries 2 years earlier with all the ethanol horror stories. It didn't scuff or break rings. Even the valves were good. It happened at 4500 RPM as well. It was odd!
Panther is offline
Old 02-20-2016 | 05:03 PM
  #148
Panther's Avatar
I decided to go with the 500efi cam because I thought the 525 might be too much. either Dart IE or EQ heads. Engines will be 9.1:1 with a 118 cc chamber. Also sent him info about having tpis do his throttlebodies. We're gonna do the mill work on the intake as well.
Any guess on numbers?
Panther is offline
Old 02-20-2016 | 07:32 PM
  #149
I see by your screen shots you have a DePac System . Hows it treating you?
dunnitagain is offline
Old 02-20-2016 | 07:41 PM
  #150
515.88453hp more w/ the 525efi cam
sutphen 30 is offline
