Starting in gear? >
Starting in gear?
Starting in gear?
Old 02-11-2016 | 10:21 AM
Default Starting in gear?
Is there a electrical switch in the shifter mechanism
That controls this? If so is it replaceable?
Wyatt is offline
Old 02-11-2016 | 10:26 AM
Just to start, what is the year and model of the boat, what engine, what control do you have, is this a new problem, have you taken the control out and inspected it? Few more details would be helpful. Short answer is yes the switch is replaceable.
No Coast is offline
Old 02-11-2016 | 10:33 AM
Thanks for reply! 1996 236 eagle eliminator with 502mpi. Not sure brand of shifter. Removed some Upolstrury and it appears there r wires going up to shifter. Would there be a model # visible if I took the shifter completely out ? New prob.
Wyatt is offline
Old 02-11-2016 | 10:51 AM
Is it a single handle that you squeeze a button to shift out of neutral or two independent levers, one for throttle one for shift.
No Coast is offline
Old 02-11-2016 | 12:51 PM
There should be a neutral safety switch in the shifter.
Griff is offline
Old 02-11-2016 | 01:12 PM
Looks like a custom two lever. No button neutral lock.
Wyatt is offline
Old 02-11-2016 | 01:44 PM
Yes checking switch out
Wyatt is offline
The Neutral Safety Switch is below the top plate.
Griff is offline
Old 02-11-2016 | 01:51 PM
Cool thank u
Wyatt is offline
