Bravo 1 steering slop
My cable is tight too... However, where the cable screws into the power unit in the back is where I have movement. The cable has a female threaded collar (nut) that the is fully tight but the male threads that are part of the power steering unit move an inch or so when you wiggle wheel causing play. The entire unit is not moving, only the part with the male threads that the cable is threaded on to (again, the nut is fully tight)
Anyone have an idea what my issue is? Do I need a new power steering unit? Is there something that needs tightening on my current unit?
