-   -   K&E 2 pc valve covers leaking all the time (https://www.offshoreonly.com/forums/general-q/334978-k-e-2-pc-valve-covers-leaking-all-time.html)
575cat 02-29-2016 10:00 AM
Get rid of them I went through that fiasco with them in the past , should o f had wing nuts been on & off so many times with different gaskets & bases , get Teague cover,s .
14 apache 02-29-2016 11:27 AM
I had good luck with mine I silicone them to the head with no gasket.
billy boats 02-29-2016 06:12 PM
They SUCK !!!!!
I have 4 sets for sale lol
horsepower1 02-29-2016 08:22 PM
I've only dealt with one set about 5 yrs ago but I remember it was really difficult to get the o-rings to fit right. I ended up using silicone grease and they finally went into their grooves but it was a battle. Since then they have not leaked a drop.
cartersfly 03-02-2016 05:13 PM
I will try some more grease but I tryed that a couple of times I am wondering if there leaking between the head and lower base panel not the cover its self?? They leak so slow and constant I just cant find eaxcutly where the oil is coming from Jim
sutphen 30 03-02-2016 05:48 PM
also,w/ the o-rings,try to get betw the o-ring and the valve cover w/ a pick and go around a couple of times.this should untwist the o-ring and help it go in properly.as your turning the nuts down,tap lightly side to side and top and bottom repeatedly as you tighten up the nuts,at 1 point the cover should just pop in.
SB 03-02-2016 05:55 PM
He also needs to check out your grinding mod.
14 apache 03-02-2016 08:10 PM
Silicone grease is also what I was using. It was the ford brake grease. Very thick.
procharged 454 03-03-2016 12:33 PM
Originally Posted by billy boats (Post 4409753)
They SUCK !!!!!
Has anyone using the new design I was told they fixed the proplem. I been itching to buy them but don't want to go threw the hassle. . If they fixed them I will buy them..I call and they said KE fixed the proplem but would like to hear first hand.. ANYONE.....
Black Baja 03-03-2016 02:44 PM
The new covers work good.
