Supercharged v NA >
Supercharged v NA
Supercharged v NA
Old 03-01-2016 | 08:34 PM
Originally Posted by SB
You can take that to the bank. Something none of us will disagree on because it's fact.
how dare you bring fact,s into the mix,LOL.
mike tkach is offline
Old 03-01-2016 | 09:05 PM
SB
I didn't, it was Mr Maine, But that's a fact. So now I did. LOL.
SB is offline
Old 03-01-2016 | 09:09 PM
phughes69's Avatar
Originally Posted by Mr Maine
If it's making more torque at 5800 then it is making more horsepower at 5800.
Hp=torque x rpm /5250
Your right, I forgot about that
phughes69 is offline
Old 03-01-2016 | 09:11 PM
phughes69's Avatar
Now I'm going to bring physics into the discussion. (learning about intergrals in Calc class) The engine with the most area under the curve is the stronger engine.
Old 03-01-2016 | 09:16 PM
Now I had it explained to me this way many years ago by an older retired navy man. Horse power is waking up with a big raging one , and torque is having your feet fly out from under you when you push it down to take a pee..
buck35 is offline
Old 03-01-2016 | 09:19 PM
SB
And that is now where we get into application.
Some lighter, and faster hull boats ...this doesn't necessarily ring true.
If we lose overall in the curve to get more power at WOT, then speed can be higher.
If heavier, slower hulls - than yesm this is predominantly true.
I'm talking speed, not necessarily acceleration, above.
SB is offline
Old 03-01-2016 | 09:30 PM
I might lose some traction when I push it down but I'm pretty sure the days of having my feet fly out from under me are a thing of the past. I've used it nearly every time I had the chance so I'm good with losing a little traction.
payuppsucker is offline
Old 03-01-2016 | 09:40 PM
I can totally relate to that.
buck35 is offline
Old 03-01-2016 | 09:45 PM
Yes sir, I had a feeling you could because IIRC we're pretty close to the same age.
Old 03-01-2016 | 09:57 PM
SB
I learned early, on my own, it's easier and safer just to lean and put your forehead against the wall. Better aim and it hurts less. Ha !
SB is offline
