-   -   Dist cap question (https://www.offshoreonly.com/forums/general-q/335096-dist-cap-question.html)
cabin fever 03-02-2016 07:21 PM
Dist cap question
Looking for a msd 8564 dist cap and not having much luck. Did this get discontinued or something?
cabin fever 03-02-2016 07:52 PM
Also is champion rv8c the best plug to run? Never been a big fan of champion plugs but the motor seems to run ok. Its 502 carb'd motor. Dont know alot about it. Plugs looked ok when i pulled em to check what was in it. Just trying to give it a tune up before the season starts.
BUP 03-02-2016 10:47 PM
Yes I already know champion plugs in any engine as I have started a backlash with this post, but I have never had a problem running RV15YC4 gapped correctly in any marine engine that calls for them.
RV15YC4 is a better cross to RV8C non Vortec heads and some Ford Marine engines takes these same plugs. These have a projected nose tip that extends deeper into the cyc head / deeper in the combustion chamber for a better idle and burning off deposits - hence better against plug fouling.
Vortec heads is RS12YC marine apps
Actually Some Volvo Penta and OMC marine apps recommend using the Champion spark plug over AC and NGK, they even have SB's about using them. Matter of fact many 2000 and back year models OMC outboards you can ONLY use Champion spark plugs. Just saying
You better make sure you are using the correct model spark plug. What year and what is the engine exactly plus stock heads, anything not stock ? Engine serial number ???
BUP 03-02-2016 11:09 PM
You can use NGK or AC
NGK should be BR6FS and here is the champion catalog
http://www.fme-cat.com/digipubZ/Cham...2013/#?page=22
picklenjim 03-02-2016 11:30 PM
The cap your looking for the number has been changed to 8437. Shows it on Summits site. Same ones I run. The rotor is 8467. http://www.summitracing.com/parts/msd-8564
TomFTM 03-03-2016 08:45 AM
I might have two of those caps new in the box , i will let u know this afternoon ..
TomFTM 03-04-2016 08:49 AM
I found the two I have .MSD 8564's new in the box . I will let them go for $40 for both including shipping to u..also have one new msd 8835(plug wire retainer). for that cap if ur interested. Tom
cabin fever 03-06-2016 07:43 AM
Tom ill take the 2 caps. Pm me how to get you paid.
TomFTM 03-11-2016 07:34 PM
Sent u a pm
cabin fever 03-21-2016 06:27 PM
Got the caps today. Thanks Tom.
