Engine Quest Head work results >
Old 04-29-2016 | 09:54 AM
  #91
Panther's Avatar
Frank's Marine Service
Congrats. I'd imagine they sound a little more snappy. I think we might be heading to the dyno next week.
In the meantime, been working on a 598" refresh and go. Found all kinds of unexpected issues from the original builder but I've addressed them all. There were only 100 or so hours on it. It's a shame... I expect it will make 850 hp when all said and done. Not EQ heads but Big Brodie O 351's.
[ATTACH=CONFIG]554820[/ATTACH][ATTACH=CONFIG]554821[/ATTACH]
Attached Thumbnails Engine Quest Head work results-img_20160426_221753351.jpg   Engine Quest Head work results-img_20160426_222027465.jpg
Panther is offline
Old 04-29-2016 | 01:59 PM
  #92
Just a quick clarification on some info in this thread. All of the EngineQuest EQ Cast Iron heads are produced and machined in our foundry in Auckland, New Zealand. The aluminum versions of the 320/360 runner BBC heads are produced through RHS/COMPCAMS. I cannot confirm the foundry location however they are pouring some aluminum in Asia.
Thanks for giving us a shot. We appreciate all of the feedback. Good luck with your projects and Happy Boating.
Cylinderheadguy is offline
Old 04-29-2016 | 02:32 PM
  #93
SB
Put $50 on 23 Black for me. Thanks !
Oh, thanks for joining up to say hi.
SB is offline
Old 04-29-2016 | 06:33 PM
  #94
what exhaust gasket are you guys using on these, I had the round ones from my 088's but they don't like up very good.
launchpad475 is offline
Old 04-29-2016 | 07:15 PM
  #95
I used a 1412 Felpro, because of the round port stellings headers. I did have to remove a little material from the top corners of the gasket. I used a dremel with a sanding wheel, to open the corners up a bit.
MILD THUNDER is offline
Old 04-29-2016 | 07:20 PM
  #96
SB
Good questions and info ^^^^
Have any of you made sure that the exhaust manifolds or headers does not protrude (block) across any of the exhaust port of the head ?
SB is offline
Old 04-29-2016 | 09:00 PM
  #97
Panther's Avatar
I didn't notice any issue with the EMI manifolds. I used a Merc exhaust gasket. I really like Mercs graphite gaskets.
Panther is offline
Old 05-03-2016 | 09:15 PM
  #98
Panther's Avatar
Sorry, 570 ft lbs @ 4300 and 540 HP @ 5500.
Panther is offline
Old 05-03-2016 | 09:53 PM
  #99
Thats with a mild cam and thru the stock mag efi intake setup? Stock compression too?
Old 05-04-2016 | 12:36 AM
  #100
Panther's Avatar
9:1 compression. Stock MPI intake manifold with 3" of runner milled out. Power hit a brick wall at 5300. Only 3 HP difference between 5300-5500. It would make a lot more with a carb instead of the restrictive EFI.
Panther is offline
