Hyd steering filter >
Hyd steering filter
Hyd steering filter
Old 03-19-2016 | 11:17 PM
c_deezy's Avatar
....and like mentioned above it looks like you want to make sure you plumb it correct, the filter is held on with an o-ring. If you were to go in, the out port, it would push the filter off and then block the out (wrong) port.
c_deezy is offline
Old 03-19-2016 | 11:24 PM
c_deezy's Avatar
Unfortunately you don't have a straight thru fitting you can look through, but I would say pull one of them off so you can get a look inside the filter housing, and if you see the end of the filter, that is your inlet.
Or you can just crack the hole thing open and get a look at it that way. Then you can inspect the filter also.
c_deezy is offline
Old 03-20-2016 | 07:28 AM
So if it were to thread in from the bottom of the housing, the top would be the inlet?
MichiMike is offline
Old 03-20-2016 | 09:34 PM
You want the crap filtered to be on the outside of the filter media.
mwicard is offline
Old 03-24-2016 | 12:55 AM
I have one (for sale) that I noticed it is stamped on one end. BUT this one differs from yours, in that it opens at the end with the flats. Yours opens at the opposite end.
Turns out my filter is definitely not Latham.
Latham rep said Fountain made their own stuff for a few years. Mine is the right color to be made by Fountain.
Looks like I'll be opening this thing up. Thx for the nice clear pic.
zz28zz is online now
Old 04-07-2016 | 12:16 PM
Took my filter housing apart and discovered both ends are threaded on. Guess they had to be a little different to avoid any patent issues. The end with the mounting bolts is indeed the outlet.
