Timing 540
Old 09-25-2002 | 01:33 PM
Nordicflame's Avatar
Thumbs up
Sorry Dennis,
didn't mean to sound critical; just wanted to make sure I understood which I think I do now. Your knowledge is very appreciated.
I like the idea of a simple curve. The less variables the better. I will be able tell real time when I'm hooked up and will pass on the results.
Later,
Dave
Nordicflame is offline
Old 09-25-2002 | 01:52 PM
26scarab's Avatar
I run 35deg. in mine. This is a Iron headed 9:1CR motor. I hope that I'm not running this too close to detonation. The motor seems to like 35 and when trying different octanes of gas it seemed to run better on 89 octane.
Also I have the dist. locked down , don't really have any problems starting
26scarab is offline
Old 09-25-2002 | 02:13 PM
jdnca1's Avatar
I run 32 on my NA 632. Turned it up to 34 on the dyno and there was no increase in power. The distributor is "locked in"..always 32 degrees. Starts and idles fine with never any signs of detonation @10.5:1 CR on 93 Octane.
jdnca1 is offline
Old 09-25-2002 | 08:50 PM
KAAMA's Avatar
I have MSD crank triggers---and with a crank trigger; once you lock it in------it NEVER moves!
KAAMA is offline
Old 09-25-2002 | 08:55 PM
dlbCheckmate's Avatar
I run 36* total, locked out advance. On a 468 BB with Jim V. wedges. No problem starting. (Tilton starter)
dlbCheckmate is offline
Old 09-26-2002 | 04:10 PM
KENNY
KAAMA, I agree with you,bigger cubes, porting. I was just asking if you tried going higher on the timming on the dyno. I think your right on with running 32 ALL summer long ,instead of 36or 38 for 1 month and melting a pistion.
Jdncal WOW 10.5 to 1 comp on 93, thats really pushing it and no sign of trouble. must be some cam what are the spec's.
I have 9.2 and run 93 and still worry.I never buy gas on the water, I fill gas jugs at the station on the street and carry it to the boat,to many stories about marine gas station's.
articfriends
13
01-07-2009 03:00 AM
hondatv
5
07-10-2006 08:40 AM
bsc
3
05-17-2006 02:09 PM
tomas_wallin
7
05-26-2005 02:06 AM
trobertsuk
5
03-09-2004 06:22 PM
