New to me blowers... Trying to guess hp
Thanks for the input from everyone like i said.... they are going to be better then the 177's I will re post if there is any mph increase and if there is how much..
Good info here http://documents.holley.com/techlibr..._tech_info.pdf
it's 8.5 Griff... thx for the info
What is your static comp ratio???? If its more than 8.5 then 7# may be too much boost on pump fuel.
One way to find out is when you get them installed and on the water. Like you said either way you'll definitely have more power regardless. With your other package you were done maxed out so your heading in the right direction regardless.
