Stud Girdle
Old 03-27-2016 | 09:46 AM
Originally Posted by MILD THUNDER
http://webster-industries.com/Stud_Girdles.html
they make some for the brodix heads ^^
Joe I was looking at those, But wondering if anyone here has installed them on Bordix heads. My buddy at Merc Racing told me they used Crane back in the day. He also told me that whatever I do use has to fit perfect, or you can do more damage then good. He said he has seen guys hammer them on, or get them slightly on , then tighten them, moving the studs. He told me people then wonder why the studs fatigue and you end up worse off then not using them at all.
Bawana is offline
Old 03-27-2016 | 09:55 AM
F-2 Speedy's Avatar
Im running Webster's but their on AFR's, they are suppose to be designed for the head their going on, not one size fits all.
F-2 Speedy is online now
Old 03-27-2016 | 10:00 AM
the reason for useing a stud girdle is to support the studs in an attempt to stabilize the valve train.if you install a girdle that is designed for a different valve angle it will try to bend the rocker stud.we all know what happens when you attempt to bend a hardened stud,it is just a matter of time before it fails.
mike tkach is offline
Old 03-27-2016 | 10:07 AM
i have installed some of the webster girdles,they are a good product that fit correctly.i also like the fact that they are american made.it is very important to follow the torque spec they send with the girdle,s.
Old 03-27-2016 | 10:10 AM
Yes, and when it comes to the AFR heads, you have to make sure you have either Version 1, or Version 2 heads, as they changed the intake studs location not long ago if I recall.
MILD THUNDER is offline
Old 03-27-2016 | 10:12 AM
Originally Posted by 14 apache
[ATTACH=CONFIG]552976[/ATTACH] This is what was on the merc 900sc I worked on with brodix heads.
are you saying the head in the picture is a brodix head?
Old 03-27-2016 | 10:15 AM
good info,either v1 or v2 is stamped on the head.
Old 03-27-2016 | 10:19 AM
I bought these comp girdles for my Engine Quest heads. They are made for the RHS heads, but being that the EQ head is the same casting basically, they fit them too.
Willie, something to consider. When ordering a set of girdles, make sure to ask what size base the included polylocks have. Some are .550, some are .600. You want them to match the rockers you are running. If you order a set that comes with .550 locks, and need .600 locks, the locks themselves are kinda pricey.
joe,can you post the part number,i think a lot of guys[including me]will be trying the eq head.
Old 03-27-2016 | 10:28 AM
Originally Posted by Black Baja
They were all 26 degree heads and had a perfect fit.
ok!
Old 03-27-2016 | 10:44 AM
14 apache's Avatar
LOL no I had to go on the internet to get a picture of the stud girdle. That is a L88 with the snow flake but the same rocker arms and girdle. I was waiting for someone to say something about that.
14 apache is offline
