prop slip formula ?? help! >
Old 09-26-2002 | 12:53 PM
jcap's Avatar
lets hear your numbers , 25 is unlikely on a modern performance hull. prop brand and type ,pitch , rpm ,drive ratio,mph? tach must be accurate and mph should be on gps,factory speedos are often wrong! you may have an error in calculating , I did ,as you see if you read the thread , the guys in here were great help .Thanks again by the way all who helped
jcap is offline
Old 09-27-2002 | 10:12 AM
fountain27ho496's Avatar
Default stats...
bravo 26 4 blade
1.5xz drive
69 mph on gaffrig speedo is best ever
67-68 usually
speedo lies by 2mph compared to gps
5150 rpm wot Thanks JC
fountain27ho496 is offline
hoozeyurdaddy
Prop Talk
3
11-22-2007 07:39 PM
lernin-t-fly
Prop Talk
3
07-19-2005 10:43 AM
offshoreratboy
Prop Talk
12
07-03-2005 10:55 AM
wd833
Prop Talk
4
05-02-2005 05:08 PM
paradigm shift
4
10-14-2002 08:12 PM
