Bbc starter and alternater wires >
Old 03-28-2016 | 06:14 PM
Default Bbc starter and alternater wires
I've been side tracked so many times with buts project and changed so many things along the way.
Do both smaller wires (yellow and tan) need to go to the small post on starter?
Also the does the black wire for the alternator ground to the alt itself?
I changed the distributors to electronic dui's.
Attached Thumbnails Bbc starter and alternater wires-image.jpg   Bbc starter and alternater wires-image.jpg   Bbc starter and alternater wires-image.jpg
getrdunn is offline
Old 03-28-2016 | 06:44 PM
14 apache's Avatar
Black wire ground to alternator case. That harness you have is probably from a point set up do not hook the tan wire up. Tan wire is for more voltage when cranking when running resistor with points.
14 apache is offline
Old 03-28-2016 | 07:43 PM
Tks. Yes it was from an old points set up. I eliminated about 5 wires I think that were lingering around the old alt and ended up with those two. One was obvious and the other seemed like it was grounded to the old alt.
So in regards to the starter just eliminate the tan wire then? Not sure why I left it at the time when I installed harness but maybe was just a safety measure just in case deal. Who knows.
Tks John.
getrdunn is offline
Old 03-28-2016 | 08:28 PM
If thats a high output 100 amp style alternator, you might want to consider upgrading the alternator wire.
MILD THUNDER is offline
Old 03-28-2016 | 08:44 PM
Good call.
getrdunn is offline
