Exhaust manifolds & risers >
Old 04-10-2016 | 04:09 PM
Default Exhaust manifolds & risers
I just removed the port side riser on my 07 496 Mag. I inspected the hose ports and shined a light inside the manifold and all ports. I see no sign of corrosion anywhere. Is there anything else I should check? Gonna replace the gaskets and reassemble.
MonkeySea2 is offline
Old 04-10-2016 | 04:14 PM
since they are dry joint, you can pressure test the manifolds with a hose. cap off hoses to risers, run hose into inlet. look inside for leaks.
dereknkathy is offline
Old 04-10-2016 | 04:32 PM
so if I have the riser off, put a garden hose on the manifold inlet and cap the outlet?
Old 04-11-2016 | 02:12 PM
anyone, anyone, Bueller, Bueller......
Old 04-12-2016 | 01:10 AM
Yes.
Or fill with 30psi of air and drop in a tub of water and look for bubbles.
Griff is offline
Old 04-12-2016 | 09:21 AM
Run a 1" hose jumper between both water outlets on the top of the manifold. Secure with breeze bands, plumb water into the manifold input on the bottom and crank water on.
Ryan00TJ is offline
