Delco Voyager for 454 with a B&M 250? >
Old 04-16-2016 | 09:21 AM
will somebody please design an ignition control setup for the small cap HEI? I mean how nice would it be to be able to buy a junkyard distributor and dial in exactly the advance you want at the rpm you want?
dereknkathy is offline
Old 04-16-2016 | 09:50 AM
SB
The Daytona Sensors box will do it, as I had used the Crane HI-6M to do it. Basically, you just bypass the module and use the magnetic pic up.
SB is offline
Old 04-16-2016 | 09:52 AM
MSD has an E curve distributor, and Crane had something similar I think too.
I still think the daytona box is the way to go though
MILD THUNDER is offline
Old 04-16-2016 | 03:36 PM
Steve H's Avatar
artselectricinc.com
Holley HP EFI does it too
Steve H is offline
Old 04-18-2016 | 03:24 PM
Originally Posted by TomZ
So much for Mallory... owned by MSD. And no longer available.
Great...
THe normal GM distributor you find in any junkyard will do. They were used as-is by Merc, Cruisader and others on the engines. THey have the screens for flash already installed from the factory. Then just pickup a D1965 module and you are set.
apollard is offline
Old 04-18-2016 | 03:38 PM
TomZ's Avatar
Gotcha. Is that module marine specific?
I'm going to fool with the Merc stuff tonight. If I get no joy out of it, then I'll go the Delco route.
Thanks!!
TomZ is offline
Old 04-18-2016 | 04:27 PM
Yes, that is a module with a basic advance curve built into it. I wonder if the automotive module has any advance in limp mode? It might just...
Old 04-19-2016 | 08:07 PM
I've read that the cheap aftermarket modules don't. No idea about the OEM. Be interesting to get a junkyard GM module and try it.
apollard is offline
