Engine surges when warm
Working on a 1995 7.4L 330HP engine with Thunderbolt V ignition. Here is what I have replaced, Cap, Rotor, pickup coil, Coil, plugs. Only thing left is the ignition modual ??? Engine runs smooth, does not idle rough and does not have a miss. I can pull full RPM at times. Seems to vary by about 300 RPMs when it surges. I would just replace the modual but they want a huge price for it. 806959 is the part number.
Pull the distributor and see how much end play there is. I bet a lot. Or take off the cap and crank the motor over and watch the rotor jump up and down. The gear on the distributor is probably toast as well.
