Merc 496HO Fuel Pump GPH?
Does anybody know what the GPH flow rating is for the 2004 and earlier Mercruiser 496HO cool fuel, fuel pumps (low pressure pump 861155A3 + high pressure pump 861156A1)?
After ECU recal'd to correct out of balance AFR of three cylinders in a lake test Diacom calculated/reported 38.5 GPH @ 43.5 psi or 40.4 GPH actual at 5800 rpm for 48 psi fuel pressure (12.8 AFR). Boat test elevation and atmospherics at time of test indicate engine was producing ~567cshp @5800 rpm at 40.4 GPH Diacom recording or 44.4 GPH projected actual flow at 48 psi fuel pressure. These GPM's all assume the fuel pump is keeping up and holding the fuel pressure at set point.
Upgraded engine has much better VE but needs about 46 GPH for same test conditions or ~50 GPH at standard dyno test conditions. Replacing 37 lb Delphi injectors with 52 lb Bosch so fuel pump can run at 43.5 psi fuel pressure for better GPH and reasonable injector duty cycles. I do not want to replace current cool fuel system unless it is inadequate for current engine.
I finally tested the GPH flow rate for the 2004 and earlier Mercruiser 496HO cool fuel, fuel pumps (low pressure pump 861155A3 + high pressure pump 861156A1).
Result was 58.1 GPH @ 13.4 volts with 43 psi Mercruiser OEM fuel pressure regulator. Test set up pictures attached. Jumper cables to running vehicle to maintain 13.4 volts is not shown.
Test fuel was E10 which weighed at 5.94 lb./gal. At 5800 rpm engine is projected to require 337 lb./hr of E10 at standard dyno test conditions of 60F air and 29.92 "hg atmospheric pressure which would be 56.7 GPH. So Mercruiser fuel pumps are adequate for my engine.
Plan B was a 67 GPH @45 psi Holley 12-920 fuel pump rated for 700hp that could in theory be adapted to be a direct replacement for the high pressure Mercruiser pump 861156A1. The tricky part would be to drill out and ream the female pipe threads on pump out put to accept the Mercruiser oring'd elbow fitting with out contaminating the pump internals. https://www.holley.com/products/fuel...s/parts/12-920
