X dimension and props >
Old 04-27-2016 | 06:48 PM
Default X dimension and props
Ok so i have been out breaking in some engines on my dominator. It seems like the boat wants to air out a bit. Currently it has 25 std mirage props. If I am measuring correctly From the bottom of the pad to the bottom of the transom plate and adding the 9.25 to accomodate for the driveshaft center im coming up with 19 3/4. Drives are off the boat for shifter cables(bravo 1) so I have no clue on prop shaft depth. What props are recommended to air this pig out
mggdoors is offline
