High performance piston rings
So wait a brand new build running around with primary and secondary power valves and AFRs below 9 (afr meter doesn't register any lower) isn't good? You must be joking. Blow by, oil usage, and cylinders that have a mirror look cause all the cross hatch is gone was the latest rage I thought
Is your avatar a butt??? It's kinda freaking me out!
The motor wasn't honed properly. It's probably down 20-30 horsepower than what it could be with the proper finish on the cylinder walls.
My thoughts on zero gap is the ring pack will get loaded up with oil needs a little blow by to push the oil down where it belongs. And I have run them but I would not any more did not like them. Gap rings work perfect and they use less oil and the pistons and chambers look cleaner. Plasma moly for me.
Don't think he's worried about rather just had to take a second glance to confirm what it was. An azz with a cam holder or set of A set of clown tits. Either way it's all good. Lol
Total seal ring company the leader in piston rings? I'd find that hard to believe.
Mahle Corporation, supplies General motors, Ford, Chrysler, BMW , Ferrari, Toyota, Audi, Harley Davidson, and over 100 other engine manufactures with rings. Just their "Aftermarket division" , had over 900 million in gross sales. Employs 1700 people, and has 23 plants around the world. over 100 production locations and 7 research and development centers.
Total seal? under 50 employees, under 10 million in gross sales, 1 location in arizona.
I'm not Donald Trump, but I'd like to think, Mahle might know a little something about piston ring design , if companies like GM, FORD, Ferrari, Audi, and BMW, are going to them for piston rings.
