88 four winns liberator bogs under throttle >
Old 05-01-2016, 07:40 PM
Default 88 four winns liberator bogs under throttle
I have an 88 liberator with cobra 350 - fires right up - idles perfect - throttle it in neutral just fine but when i put it in gear it boggs out like its starving for fuel or choking out ???
Johnsnyder34 is offline
Old 05-02-2016, 06:05 AM
been sitting ? if so the carb(QJet) I assume may need gone thru and cleaned, this alcohol fuel when sits leaves one heck of a mess inside, just did one on a friends boat 2 weeks ago..also if still original points could has closed up, fuel filter clogged, have also seen accel pump plunger deal and causing this as well..
ezstriper is offline
Old 05-02-2016, 07:27 AM
Timing, compression test. Start with the basics...
dereknkathy is offline
Old 05-02-2016, 08:05 AM
i agree with ez,sounds like a carb issue.
mike tkach is offline
Old 05-02-2016, 02:06 PM
Welcome to the site by the way!!!
BBCLiberator is offline
Old 05-02-2016, 02:14 PM
SB
Received 3,124 Likes on 1,406 Posts
1st thing - check to see if choke is sticking closed
SB is offline
Old 05-03-2016, 01:26 PM
RSCHAP1's Avatar
If the shift cable has drag to it, it will trigger the shift interrupter switch.
RSCHAP1 is offline
Old 05-03-2016, 03:20 PM
BUP
Stock OMC Cobras had Holley carbs and if it was the shift interupt switch it would completely stall as soon as you put into gear. IMO carb issue and or fuel delivery issue.
BUP is offline
Old 05-03-2016, 04:24 PM
Isn't that what it is doing?
Old 05-04-2016, 07:07 AM
not all, I had a boat I bought new in 88 with twin SB cobras, had q-jets, and yes their shift interrup system was a pain, 1st switch killed cylinders, 2nd switch bypassed 1st to run normal, had issues with mine on occasions
