msd?
Does anybody have any info on replacing a 6m box with a GM 4 pin module. Also would this work with a crank trigger.
just replace the whole deal with a HP hei remove the vac advance(kit made to block off) get the 2 correct wire connectors and roll on..
I misunderstood, you want to delete a 6m box?
this thread http://www.offshoreonly.com/forums/g...placement.html |
Originally Posted by Wobble
(Post 4435930)
if you can mount it in or on a good metal surface because it needs a heat sink then yes it could replace a box, crank trigger would replace the wires that come from dist magnetic pickup assuming the crank pickup has a compatible signal (which it normally would)
or you can just carry a spare box |
1 Attachment(s)
This may be what your thinking about :D
Yes, thanks.
