would you notice 100 more ft.lb. torque >
Old 05-15-2016 | 05:21 PM
Default would you notice 100 more ft.lb. torque
in a single engine boat (same stroke, same rpm) lets say hp and torque curves are similar, w/ the exception one engine is up a hundred
would you notice the engine that was up 100
outonsafari is offline
Old 05-15-2016 | 05:31 PM
SB
Hell yah, but if you don't, it's time to throw away the boat and/or driver. LOL.
SB is offline
Old 05-15-2016 | 06:32 PM
I have a formula 242. Over winter I added 100lbs of torque everywhere. It is much more fun now. Very noticeable.
79formula is offline
Old 05-15-2016 | 07:44 PM
Without a doubt on any engine but think of it on a 400 to 500hp engine that's like 20-25% more power and 7 to 8 mph.
getrdunn is offline
Old 05-15-2016 | 07:51 PM
Would you notice a kick in the balls? Yup...haha
Mr Maine is offline
Old 05-15-2016 | 09:25 PM
I don`t know what these guys are talking about , you won`t notice at all.
ICDEDPPL is offline
Old 05-15-2016 | 11:02 PM
plan is stay inside design limits of drive. specifically 500 torque w/ operating range 5500-6000, another member i spoke w/ said 5000-5500 would be better
drive is b1 sweptback, it's at mr. gadgets getting some mods, setup, and drilled and tapped so i can run the oil thru a cooler.
Old 05-16-2016 | 05:41 AM
what pump you plan on running to move the oil?
sutphen 30 is offline
Old 05-16-2016 | 07:36 AM
first or second pump in the link, mocal continuous duty bronze gears. (open to suggestions on pump)
http://97.74.32.155/files/pump.pdf
http://www.summitracing.com/parts/der-25049/overview/
http://www.hardin-marine.com/p-13581...il-cooler.aspx
Old 05-16-2016 | 06:30 PM
You will make more power if the torque curve is the same +100. At 5250rpm you would have 100hp more! At 2625rpm you would have 50 more HP
hogie roll is offline
