Holley EFI in a boat - Doesn't Repeat >
Old 05-22-2016 | 03:55 PM
  #41
I'm sure it changes from boat to boot with different exhaust set ups. I have used the holley o2's and also the Bosche one. You can them them for a VW, and they are like $50 each compared to over a hundred for the holley.
I do the same as above, manual tuning below 1200.
launchpad475 is offline
Old 05-22-2016 | 06:31 PM
  #42
Just a suggestion, join "Holley EFI Forums" and post your problem over there. I had a problem on a Sunday morning at 10:00 out in the boat. I posted the problem to the forums from my iPhone while in the boat. Then when I got home I sent member (S2H) on the forums my datalog and global folder and he had my problem figured out and I was back to 100 percent that afternoon. S2H ( Schexnayder Racing) is really good with these systems.
hadleycat is offline
Old 05-22-2016 | 11:09 PM
  #43
yeah that guy and Danny over there are super sharp.
Old 05-24-2016 | 10:18 AM
  #44
MER Performance's Avatar
Originally Posted by scarab39
I'm switching to Holley. is anyone here ( Haxby? ) a reseller for Holley? I need two dominators
Yes,.....
MER Performance is offline
Old 05-24-2016 | 10:21 AM
  #45
You can use it for an emergency, but the Holley is calibrated with a resistor ....
Old 05-24-2016 | 10:36 AM
  #46
you can cut the bosche plug off, and re pin the Holley o2 with the resister still in it.
Old 05-24-2016 | 10:46 AM
  #47
Go on....i'm listening. lol
Do you have a link with some more info on this?
Wasted Income is offline
Old 05-24-2016 | 01:19 PM
  #48
So in the top pic is the Holley plug, I chop that off. Leave the brown wire on the left, that is the resistor. Then I re pin it to the bottom after cutting off THAT plug which is the $35 one you can get on Amazon Prime. (butt connectors work too). A buddy of mine did the research on this, and I just copied it. Been doing it this way for 3 years. Good luck-
Old 05-24-2016 | 01:43 PM
  #49
EDIT: Nevermind....I'm running the NTK sensor on my turbo E85 deal. Know of a cheap version of the NTK?
Old 05-24-2016 | 02:59 PM
  #50
no, but you can change from NTK to Bosche in the software with one click!
