Hydraulic steering set up.. >
Old 05-18-2016 | 11:09 AM
Default Hydraulic steering set up..
I'm working on piecing together a hydraulic steering setup for my Corsa..
I came across a set of Latham 7" stroke rams so it'll all fit between my trim tabs..
Trying to figure out which helm to go with..
Using a cylinder volume calculator I come up with needing I come up with 22.14 cubic inches needed to go from lock to lock..
SO, If I go with a 6 in³ helm it'll be 3.6 turns and if I go with a 7.56 in³ it'll be 2.9 turns lock to lock...
....and of course there is nothing in between the two...
Which one would you go with ??
THANKS !!
Boatally Insane is offline
Old 05-18-2016 | 11:55 AM
2.9 turns! When I bought my full Zeiger system I was warned by others to specify a 120 cc (7.322849in³) helm to get just under 3 turns lock to lock. Otherwise I'd end up with 4 turns or more.
thirdchildhood is offline
Old 05-19-2016 | 12:21 PM
That's the direction I'm leaning, but my fear is that my steering may end up too "twitchy" at 100+ mph...
Old 05-20-2016 | 06:21 AM
getting the helm unit mounted correctly is a HUGE deal, the slightest bind to one side will make it twichy as hell !!! had to have a custom column made to get my 253 right
ezstriper is offline
Old 05-20-2016 | 01:48 PM
Its completety of topic , when you install a helm , does it matter wich way the fitting on the helm go?
JMPH is offline
Old 05-20-2016 | 08:22 PM
I like twitchy or responsive it takes a lot less effort to drive through chine walk with a responsive helm. I've ran both and I'll take twichy any day.
Black Baja is offline
Old 05-21-2016 | 07:47 AM
not the twitcy i ran into...was unsafe to drive, and on the fitting question no can mount in any direction
Old 05-21-2016 | 08:24 AM
Yes, there is a pressure and return and they need to be correct. Then there is a left and right and they need to be correct otherwise the boat will turn the opposite way.
Mr Maine is offline
Old 05-21-2016 | 11:01 AM
can anyone ID/size this helm?
211 1098 001
[ATTACH=CONFIG]555789[/ATTACH]
[ATTACH=CONFIG]555790[/ATTACH]
Attached Thumbnails Hydraulic steering set up..-img_0022.jpg   Hydraulic steering set up..-img_0025.jpg
phragle is offline
Old 05-21-2016 | 01:44 PM
But does it go straight up , it will get in the way of the dash wiring, it would be a lot better if it came out the side?
JMPH is offline
