Need Starter Advise gm572
I am looking for some advise on a new starter for a GM 572 NA standard compression engine. Had an arco 30470 on and ate the flywheel. Had to pull engine to replace the flywheel, total pain and a major job. Looking to replace with another starter just to be safe. Anybody have any advise or experience on this?
Thanks. |
Do you have standard block mount or bell housing top mount starter. Make sure and confirm your new starter engages properly before you reassemble everything also. Shims? No shims? You should be able to slide the end of a paper clip between starter flywheel when fully engaged. I usually use a hook tool to slide the starter gear out.
The last two I installed recently one needed one thin shim and the other needed a thick and thin one. |
Thanks. I will definetly be making sure everything is aligned and shimmed right. I checked everything on this one the same way you spoke of and still had this issue. I went from a hitachi type to this arco. Seemed good for a while then chomp chomp chomp on the fly wheel. Only seems to be engaging the treeth about half way as well as best. Am thinking that might be and issue although no adjustment on this starter for that type of shimming.
Had a car guy that was killing flywheels flex plates had to machine the nose of the starter for less teeth clearance and more depth on the teeth. Is the pinion climbing over the teeth on the ring gear?
Were you getting kick back while cranking at all? Also what type of flywheel is it. You have a replaceable ring gear or is it one piece solid flywheel. Something seems really strange why you wiped the teeth off. 168 tooth correct? Sorry to not have recommended starter yet. I'm trying to help you figure out why the old starter chewed the teeth off. 14 Apache had a good post. Would just suck to go through this again. I'd look at cpperformance.com for starter. And maybe talk to rep about what went on also.
http://www.powermastermotorsports.com/ mine is 16 yrs old..works like a champ..you might want to put a starter button in and push the button and turn the key on for easier start..
Thanks Fixx, Have a push button set up already.
Thanks Apache 14, No it is not it just ate the ring gear teeth off 1/16 from the base of the teeth. I don't know it it got loose a little or what. I removed it at the first sign of trouble. Bolts seemed tight, inspected starter and what I could of flywheel and reinstalled. just kept a bar on the boat to rotate away from the bad spot for the last month of the season.
I got away from the hitachi style because I was told they weren't as strong. IDK. The local shop carried arco and matched this one up for me. I especially don't like the fact that the bendix only engages about half of the ring gear when it is extended to its full throw. Seems like it should come a little farther to me.
Yes it is a 168 tooth two piece.
