water pressure problem
You may want to try replacing the water hose in the transom assemblies. They could be getting sucked shut. There is also a possibility (if this is a stepped boat) that the hull could be leaving to much air in the water and you are pumping air through the cooling system rather than water. If this is the case you will have to add thru hulls about 4" behind the rear step. There is clean water there. I would start with the water hose though.
I've found wood chips in hoses that float around and then finally clog the first cooler enough to restrict water flow. Come to a stop and they must have floated back away from the cooler. I'm not sure that is exactly what happened, but it seemed to resolve my issue at the time.
Did you flush each hose out or just check the coolers?
