Off the shelf Cam- Dyno results >
Old 06-23-2016 | 10:06 AM
  #91
Smallest cam im seeing with .680 lift with 1.7 rocker is 255* there.
MILD THUNDER is offline
Old 06-23-2016 | 10:16 AM
  #92
Panther's Avatar
Frank's Marine Service
Top of Page 29; http://www.compcams.com/Technical/Ca...terCatalog.pdf
Lobes 13861 and 13862 as I posted specs above.
Panther is offline
Old 06-23-2016 | 10:44 AM
  #93
I see them now. Different catalog.
It be interesting to see the lifter acceleration rates between Full Forces 241 .680 lift cam, and the HUC 243 .675 lift cam. Without knowing the rated duration on full forces cam, how can you tell?
Attached Thumbnails Off the shelf Cam- Dyno results-screenshot_20160622-113945.jpg
Old 06-23-2016 | 01:02 PM
  #94
Panther's Avatar
You got me, I'm not sure. I don't know enough about fluid dynamics and kinetic energy.
I just completed a swap from a CompCam with 13054/13056 lobes over to a custom grind with almost identical duration numbers @ .050 and same LSA but with higher lift (663/671). We saw a gain of 100 rpm in the boat on the big end without re-jetting. The theory that the Brodix BB3 Xtra 354's would like added lift worked. It was a $500 gamble that paid off.
https://youtu.be/u-5P0vw1UqQ
Panther is offline
Old 06-23-2016 | 01:06 PM
  #95
articfriends's Avatar
Originally Posted by getrdunn
I'm curious as to cam design for a blower and dynoed without.
A while back my 540 blown made 1115 hp, made in 650's NA with blower cam (thin oil) I think was 248/255 @.050 and .650 lift at 8.3-1 compression using modified MPI intake, made in 640's with thick oil, last time same motor and intake but with even bigger cam i think at 255/263 at .050, 680 lift made 630-635 hp NA on my own dyno, way to much cam for low compression motor built to run supercharger, dynoed it to have a NA tune for when blower fails or running saltwater, hoped to make more BUT compression vs a ton of duration is going to be sluggish at a certain point so it is what it is, Smitty
articfriends is offline
Old 06-23-2016 | 01:28 PM
  #96
Cams seem huge but evidently work well with your blower.
getrdunn is offline
Old 06-23-2016 | 01:38 PM
  #97
SB
Those HUC lobes. Oh my. And the description. Who woulda' thunk ? Don't think I'd be man enough without a bunch of people using those first. Lol.
SB is offline
Old 06-23-2016 | 01:42 PM
  #98
Panther's Avatar
HUC a Loogie! lol
Panther is offline
Old 06-23-2016 | 02:34 PM
  #99
SB
LOL.
Hop Under Control ?
SB is offline
Old 06-23-2016 | 06:16 PM
  #100
Originally Posted by Full Force
In my case I am the builder, I used Bob because he was recommended to "design" my heads, cam, and valvetrain combo...I got a weak recipe and one for potential disaster. lifter to bore clearance advice I asked about was off, and the "custom made for me and marine use" heads were not made custom at all, just had Inconel valves... he bashed me to others behind the scenes and also guys said "any engine builder should know better" well I am not a builder by trade and Bob knew that, he should have made some different choices in advice knowing that....
it's over now, engines run great and I am boating, however to spend 35,000 and go slower sure still hurts...
Just ran across this a little earlier. I'm not trying to raise your blood pressure but thought it was somewhat interesting. How accurate the info is I'm not sure.
http://www.chevelles.com/forums/13-p...o-results.html
getrdunn is offline
