High Oil Temp - Chasing a ghost/sender?
The plumbing looks a little funny to me show a close up of where they meet at the block. Does it have a thermostat in it?
A regular/stock block adapter only has two fittings, the first line out of the block to the outside fitting of the filter is correct, then the other filter line should go to the port side of the cooler, then the starboard line of the cooler should go to the return side of the block, I think lol
