are top mount starter flywheels different >
Old 06-21-2016 | 07:49 PM
Default are top mount starter flywheels different
in case i opt for a different engine,
are the top mount starter flywheels the same as block mounted starter flywheels,
is it ring position, or just a totally different animal
thanks
outonsafari is offline
Old 06-21-2016 | 08:05 PM
The ring is towards the back on a top mount and towards the front on a bottom mount . If the flywheel is machined on both sides you can simply heat the ring gear with a torch and tap the ring gear to the oposite side
billy boats is offline
Old 06-22-2016 | 07:18 AM
I just had to have my flywheels machined so I could flip the gear into the other side.
indysupra is offline
Old 06-22-2016 | 04:50 PM
14 apache's Avatar
What they charge for machining? Thanks
14 apache is offline
Old 06-22-2016 | 04:56 PM
F-2 Speedy's Avatar
I just went through all of this, switching from a bravo to a tranny boat, as stated above I was able to move the ring but also had to machine out the rear center of the flywheel so the coupler would set flat against the face, lucky for me my 540's are internally balanced and it all worked out.
F-2 Speedy is offline
Old 06-22-2016 | 05:08 PM
bck's Avatar
bck
Charter Member#568
I had mine moved. Takes a lot of faith not to put a few welds on to make sure they stay.
Straight bottoms and flat decks
bck is offline
Old 06-22-2016 | 08:54 PM
I tig welded mine. They charged 150 per flywheel.
Old 06-22-2016 | 09:59 PM
you guys are awesome,
Old 06-23-2016 | 05:30 AM
We always mig them. Dealing with two different steels. The ring gear is hardened. So when welded they cool at different rates. Usually end up with a crack in the center of the weld when tigged unless you pre-heat in an oven or with a torch.
Black Baja is offline
Old 06-23-2016 | 09:59 AM
14 apache's Avatar
Try using Inconel wire when tig welding difficult to weld and hard alloys wont crack. Welded starter pinion gears to the bendix on my 24v starters no cracks.
