I have a merc 525 engine miss at 4800
The crank sensor is the only thing that came up when we googled it we tried 2 different ones and still the same and the crank trigger wheel is not rusted it runs ok till the temp goes up ,the water temp is a little hi 180 thanks for the response
On our Formula 353 with 525s we had an issue at higher rpms there was a random "ping" sound , like tapping a hammer on hollow metal very lightly, starboard engine. Replaced the cam sensor assembly and fixed it. And yes it was $800 for the part.
These them Eddie ?
ACDelco 213-350 GM Original Equipment Engine Oil Pump Driveshaft with Camshaft Position Sensor
https://amzn.com/B000EQPA00
