600sci/700sci Crank Position Sensor Code >
Old 07-03-2016 | 10:42 AM
Kelly O's Avatar
Default 600sci/700sci Crank Position Sensor Code
Hoping someone here has experienced this.......
Freshwater 600sci, runs perfectly. When rpm's exceed 4900, I get a Smartcraft alarm for the crank position sensor. Cleared codes, installed new sensor, and condition still exists.
Connectors and harness are clean/tight/check out fine. Are there other sensors in this same circuit which could cause this alarm ?
Spark plugs all look uniform. Anyone else experienced this ?
Kelly O is offline
Old 07-10-2016 | 04:01 PM
Kelly O's Avatar
Headed home from Boyne after a weekend with the MTI, need to get back to this issue.
No ideas from previous experience ?
Kelly O is offline
