Looking for help on my 502
Well tonight I did a leak test and confirmed the problem when air started coming out the adjacent cylinders.
Head gasket was blown between each cylinder. Good thing I ordered Fel-Pro gaskets and ARP bolts today just in case.
Most definitely. May even want to take that head in to see if it needs to be resurfaced. Kinda unusual it would blow between ALL the cylinders on that side. Need to get that head off and confirm your problem. I had one blow last year between 3-5. In my opinion I doubt you have any ring problems or damage from returning to the dock..
A guy brought me a hp 500 carb motor that blew the head gasket between all the cylinders on one side last year and block and heads were both channeled so you might be pulling it out once you get the head off, fwiw, Smitty
So pulled both heads off and the right side was blown between every cylinder. The left was starting to go between every cylinder. I am sure the previous owner knew it had got hot at some point (just guessing) since it recently had a new sea pump and water pump installed before the sale. Lesson learned and it is used so it is what it is. Long block will be here tomorrow, mine was a good core. Will be putting it in first of next week
