Mounting remote PS reservoir >
Old 07-07-2016 | 06:00 AM
Originally Posted by mike tkach
there are a lot of mercury marine power steering pumps that hold a small amount of ps fluid it the small built in reservoir,the remote reservoir is nice for seeing the level but not a necessity.
I agree with Mike, it is not a necessity but it is kind of like a car in that it is makes it easy to check. If you see red fluid in the bilge, find the leak.
BenPerfected is offline
Old 07-07-2016 | 07:10 AM
if you install it it will need to be above the pump, but will work fine even dual ram without it, make sure you have a P/S cooler and I suggest using GM non foaming HP P/S fluid, ran my dual ram system this way for 5 years
ezstriper is offline
Old 07-07-2016 | 08:40 AM
vintage chromoly's Avatar
Thanks for the replies.
I'm going to go without it.
I have a dual ram full hydraulic system.
vintage chromoly is offline
Old 07-07-2016 | 03:47 PM
14 apache's Avatar
Needed for dual pumps.
14 apache is offline
