Do all 496's have water pressure sensors ? >
Old 07-07-2016, 11:02 AM
HiPerf2000's Avatar
Default Do all 496's have water pressure sensors ?
I have a 2006 496 mag that is running a little hot. I have analog gauges. I hooked up my rinda to verify temp and also to see if I can look at the water pressure psi numbers. I don't see water pressure while scrolling on the rinda ??
Do I have a water pressure sensor somewhere in the cooling system ? I know its not on the seawater pump since I just changed the impeller.
Looked at BAM parts and couldn't find anything sensor related for my serial number.
HiPerf2000 is offline
Old 07-07-2016, 11:22 AM
The hose that goes to the water pressure gage is connected to the sea water pump on my 496 mag ho.
Bama is offline
Old 07-07-2016, 11:24 AM
donzi matt's Avatar
The water pressure sensor on an 06 is located on the power steering cooler at the back of the motor. The ECU does monitor water pressure, and I have seen it on my Techmate Pro.
donzi matt is offline
Old 07-07-2016, 11:25 AM
Forum Regulator
Sydwayz's Avatar
Received 1,219 Likes on 527 Posts
Yes, they absolutely do. But I don't know where it is on your model.
Sydwayz is offline
Old 07-07-2016, 11:49 AM
Yep, spot on info.
Ryan00TJ is offline
Old 07-07-2016, 11:50 AM
+1
Keith Atlanta is offline
Old 07-07-2016, 11:56 AM
First, take the ends off your closed cooling log. Run a hanger thru al the little holes. Flush it out with a hose and see what comes out...
How many hours or on the engine?
How many hours since last impeller install? (or approx)
You may need a new inpeller. If you did one in the last 100 hours maybe its breaing down...
Another problem on 496's is the impeller scores the housing and leaves the impeller less effective so even with a newer impeller you may not be setting off alarm but are also starving the engine. Personally I like JR Marine Rebuild kits I have had really good results. Heck, I think they should be installed no matter what but thats my .02
Old 07-07-2016, 12:17 PM
HiPerf2000's Avatar
300 fresh water hours on motor. just put a new impeller and plate kit in to try to get it cooler. Old impeller and plates were fine.
I pulled the caps off the head exchanger, and it is clean. I flushed it anyway, no restrictions. I also backflushed from heat exchanger inlet back to the seawater pump. I had a few small pebbles come out.
The boat idles fine at 160, but climbs to 180 when running at 3400. Also when idling at 160, I can increase rpms in neutral,and the temp drops to 150 like it should. Just not sure why it running hot (on the gauge) while on plane....(I haven't ran it with the Rinda while on plane to verify...I plan on doing that this weekend).
The marina is very low this year, and I have been running through mud everytime I leave my slip.
Old 07-07-2016, 01:18 PM
BUP
run it with the scan tool and monitor water pressure PSI and coolant temp and manifold temps it will show u on the scan the parameters. Check to make sure what ever gauges you have match the scan tool.
do you have sea strainer (s) ?
your engine serial number will determine parts location and part numbers - all merc 496's are not the same
if your engine was truely built in 2006 then water pressure should be installed in the power steering cooler.
I CAN NOT TELL everyone how important it is to KNOW your engine serial number and post it. This determines everything for marine engines. Year model of hull and or year on titles means 100 % NOTHING.
BUP is offline
Old 07-07-2016, 01:19 PM
If you are not getting an alarm when running, I wouldn't be concerned with the temp on the gauge, those are not terribly accurate to begin with. The fact that it runs 160 at idle, runs hotter underway and cools down off plane is normal, my motors behave the same way. The motor ECU will let you know when things are getting too hot via alarms. I think it will complain north of 190 degrees.
I highly suggest getting Smartcraft monitor installed. It takes all the guess work out of gauge readings and you get great benefits like fuel consumption, basic alarm info, etc. Easy to hook up and will pay for itself in peace of mind.
techman is offline
