Value of 525 log block >
Old 07-18-2016 | 09:16 AM
Default Value of 525 log block
Looking at my options for replacing or rebuilding my 525. What would a long block be worth that needs a piston, bore or sleeve replacement and one head needs machine work? Thanks
Rheeder218 is offline
Old 07-18-2016 | 07:45 PM
Maybe 2K. There is nothing very special about a 525 once you strip off everything
snapmorgan is offline
Old 07-18-2016 | 08:02 PM
How many hours on it? I'm guessing along with the said work to be done one would want to have block hot tanked and magnafluxed, crank and rods cked, new bearings, rings, hone job, valve job, deck surface cked, both heads cked, spring pressures within tolerance, gaskets and so on. So in a nutshell with adding up what you have that could be sold as in parts I'd think 2k 2,500 at the most.
getrdunn is offline
Old 07-19-2016 | 02:17 PM
what year 525 ?
ezstriper is offline
Old 07-19-2016 | 09:29 PM
Originally Posted by ezstriper
what year 525 ?
Kinda hard to say the block was replaced in 10. Boat is a 04
Old 07-20-2016 | 10:00 AM
I mean 525 SC or EFI
Old 07-20-2016 | 05:46 PM
I assumed he meant 525EFI, a 525sc would probably be worth half that blown up. Surely in an 04 model boat it would be EFI
Old 07-21-2016 | 08:19 AM
agreed original post just said 525, looking for a 525SC
