-   -   what transom work is needed to convert TRS to SSMIII drives? (https://www.offshoreonly.com/forums/general-q/339903-what-transom-work-needed-convert-trs-ssmiii-drives.html)
Full Force 08-03-2016 05:23 AM
Looking at converting from TRS to SSMIII, what EXACTLY needs done besides having the proper parts? especially the transom...
MILD THUNDER 08-03-2016 06:28 AM
3 Attachment(s)
I believe you will have to open up the hole a bit where the driveshaft goes thru. Then plug the old mounting holes up, and drill new mounting holes for the ssm transom. Swap tailstocks on your tranny's to the SSM tailstocks, add the SSM style mounting ears to your trannys too. Then remove your angle brackets off the stringers, plug those holes up. Once transom assemblies mounted in place, hang engine in place, install rear bolts thru ears, slide alignment bar in place to align engines, then drill new holes in stringer for the angle brackets.
Full Force 08-03-2016 06:36 AM
Sweet thx Joe, as you know we are already talking about this, hope I can make it happen maybe, I plan to use transmissions from doner boat if they are better then what I have, we will see if deal happens... If not they pop up at times one day, now to find a #4 doner lol
Full Force 08-03-2016 06:38 AM
I guess re doing transom completely is my biggest question, seems I don't have to completely anyway...
F-2 Speedy 08-03-2016 06:49 AM
I checked on this, and it was about 6k just for the transom work, this was a complete fill and recut and paint, it adds up quick
Rookie 08-03-2016 03:45 PM
Best deal I've found. I'm actually thinking about them...
https://www.facebook.com/groups/1017...29521880548765
F-2 Speedy 08-03-2016 05:02 PM
can you translate, I dont do fb
Full Force 08-03-2016 07:56 PM
Saw those that's a great deal, I plan to buy a whole boat so I get everything I need, then sell the rest and have free conversion... We will see..
Full Force 08-03-2016 07:57 PM
Whole setup looks to be complete 11,000.00
Rookie 08-03-2016 07:58 PM
Translation... Facebook Powerboat Swap Shop has a ton of great deals and you are missing out if you don't have it. lol
I'm not a FB fan either. It's just a reality we live in today.
Everything you need to do a # III conversion with transom assy's, tranny's and fresh drives $11,000.
