How can I tell if my motor is inter or ext balanced >
Old 08-03-2016 | 04:24 PM
Default How can I tell if my motor is inter or ext balanced
It's 1990 502 mag carb I've look every where with the merc serial #. And in does not same or I'm just not seeing it ,,it took a **** I have a spare puppy 489 deal that is inter,,in my v drive ,,,I have to change out the flywheel to bolt up to the bravo drive ..
jdf4068 is offline
Old 08-03-2016 | 05:27 PM
Should need 168 tooth externally balanced flywheel. Your 489 will not work due to being internally balanced. Do you have any history on the 502 you currently have?
getrdunn is offline
Old 08-03-2016 | 05:44 PM
I have a spare flywheel $50 + shipping from Houston area if you need one.
GLENAMY 242SS is offline
Old 08-03-2016 | 05:51 PM
F-2 Speedy's Avatar
your 502 ( if stock ) should be ext balanced from Mercury, if the 489 is int balanced go get a neutral flywheel, I just put a 168 tooth ring gear on a flywheel for an internal balanced 565
F-2 Speedy is offline
Old 08-03-2016 | 07:20 PM
History on it was it run but not good ...so we go look at boat like it ..awhile c heckling it out ..I forgot to pull kill switch ,just to see if it would roller over easy or was it dragging.type deal ..will it busted off ..and we heard **** load of valve noise ...so I still ran a comp check on the odd bank 90-120 psi..so we knew going in it had upper end issues ,,well I went to hunting the issues ..with my chief mech ,,my wife she a gear head .so we start on the even back and notice the valves not moving like they should ..so we going reset the lash ..and find a bent push Rod ,,,call it a day ..go digging thru my spare parts found a rod ...go to putting rockers on .2 intake valve dropped out ..tunes out the keeper broke ..found all off it ..try to pull valve back up notta going to move ..so ..I start tearing it down to get out of boat ,,,bent valve ..3 piston. Not pretty,,, heads look good other then valve guide on bent hole ..so we r going to rebuild it .,,,I was thinking I could use the flywheel and balance on the 489
jdf4068 is offline
Old 08-03-2016 | 07:32 PM
Thanks guys ...I was just trying to use would I have on had
jdf4068 is offline
Old 08-03-2016 | 07:33 PM
Is it inter and where in houston
jdf4068 is offline
Old 08-03-2016 | 07:52 PM
Flywheel, came off Gen IV BBC (Mercruiser) casting no's on wheel are 14098806 N also 1660
Location, NW of Houston in Resennance Festtival area (Magnolia)
Let me know if this works for you.
Old 08-03-2016 | 08:07 PM
Not sure what the kill switch had to do with anything. There is a lot in your second post that doesn't really add up. Not sure if it's spelling or lack of English 101. Lol. You mentioned "will it busted off" ??? "After digging thru spare parts you found a rod". ??? If you plan to rebuild it which it sounds like it needs you should bring new flywheel along with rotating assm and have balanced. Have your wife pick up a BBC how to build book.
Not trying to bust your balls cause I'm not the fartest smeller (smartest speller) either but seriously reread your thread in the morning, long after happy hour ends. Lol. Seriously good luck though. You'll be awe-ight
getrdunn is offline
Old 08-04-2016 | 05:38 AM
Don't be a dick .for one thing ..,,yes I had a few drinks ,,,second. I promise u my wife knows more on motors then you .i will just say that at let it be ,,,
jdf4068 is offline
