-   -   Winter storage (https://www.offshoreonly.com/forums/general-q/34004-winter-storage.html)
283CHECK 10-03-2002 04:44 PM
Thanks Panther I have a couple more weeks before its time but just want to make sure I have my ducks in a row..
Gordo 11-07-2002 01:46 PM
Originally posted by Sydwayz
Don't fog the motor by spraying thru the throttle body!!
:confused:
Why?
Also,
Panther wrote; "Do it the right way, and make sure you drain the block before running the antifreeze thru it."
RV anti freeze or Sierra ? Could be a big difference here.
Before you ask, I have a manual.
cgarrett 11-07-2002 05:55 PM
This is what is on Mercury's website about why not to fog an EFI.
Why is Storage Seal Rust Inhibitor not recommended in the newer EFI and OptiMax engines?
A: Storage Seal Rust Inhibitor uses a thick base designed to protect the internal engine surfaces. In some applications we have seen a build up of the thick base inside the injectors, causing the injectors to stick or operate incorrectly. On these models we recommend Quickleen and 2-cycle engine oil as a replacement for Storage Seal Rust Inhibitor. Quickleen is used to clean the injectors. The engine oil lubricates, as well as prevents rust from forming. We continue to recommend Fuel System Treatment and Stabilizer to help prevent the formation of varnish and/or gum in the gasoline. Always follow the storage procedures outlined in your Operation, Maintenance & Warranty Manual or Service Manual.
US1 Fountain 11-07-2002 06:57 PM
My 1st yr to use the antifreeze also. Motor has usually been apart by now last couple of yrs. :rolleyes:
Couldn't decide between the nasty green stuff or the safe RV/Marine stuff. No where on the RV antifreeze does it say anything about having rust inhibitors, which is what I want! No winter corrosion thing going on while stored. I assumed that was because it is mainly for water lines and holding tanks which are mainly plastic where the only conscern was freeze protection. So.........
I used the NASTY!
