Winter storage >
Winter storage
Winter storage
Old 10-03-2002 | 04:44 PM
283CHECK
Thanks Panther I have a couple more weeks before its time but just want to make sure I have my ducks in a row..
Old 11-07-2002 | 01:46 PM
Gordo's Avatar
Charter Member #94
Originally posted by Sydwayz
Don't fog the motor by spraying thru the throttle body!!
Why?
Also,
Panther wrote; "Do it the right way, and make sure you drain the block before running the antifreeze thru it."
RV anti freeze or Sierra ? Could be a big difference here.
Before you ask, I have a manual.
Abby-someone
Gordo is offline
Old 11-07-2002 | 05:55 PM
cgarrett's Avatar
This is what is on Mercury's website about why not to fog an EFI.
Why is Storage Seal Rust Inhibitor not recommended in the newer EFI and OptiMax engines?
A: Storage Seal Rust Inhibitor uses a thick base designed to protect the internal engine surfaces. In some applications we have seen a build up of the thick base inside the injectors, causing the injectors to stick or operate incorrectly. On these models we recommend Quickleen and 2-cycle engine oil as a replacement for Storage Seal Rust Inhibitor. Quickleen is used to clean the injectors. The engine oil lubricates, as well as prevents rust from forming. We continue to recommend Fuel System Treatment and Stabilizer to help prevent the formation of varnish and/or gum in the gasoline. Always follow the storage procedures outlined in your Operation, Maintenance & Warranty Manual or Service Manual.
cgarrett is offline
Old 11-07-2002 | 06:57 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My 1st yr to use the antifreeze also. Motor has usually been apart by now last couple of yrs.
Couldn't decide between the nasty green stuff or the safe RV/Marine stuff. No where on the RV antifreeze does it say anything about having rust inhibitors, which is what I want! No winter corrosion thing going on while stored. I assumed that was because it is mainly for water lines and holding tanks which are mainly plastic where the only conscern was freeze protection. So.........
I used the NASTY!
US1 Fountain is offline
stuener
Northern Illinois Offshore Club
17
02-11-2008 10:32 PM
Wild
08-25-2006 07:44 PM
speedchangesyou
2
09-19-2005 05:23 AM
speed demon
Powerquest
1
09-16-2005 06:46 AM
36spectre
06-04-2003 09:17 PM
